J
Guest
Is their anywhere you can buy a stock rebuild kit for the 2.2L? I have about 132,000 on mine and its gottin tired. The car has been ran hard it whole life, leaking oil from somewhere on the rear right corner of the block, and does blow some smoke from time to time. Not looking to make a drag motor, just want to refresh-in it up as I might be selling it soon.
There's no "kit" or anything. But if you've got the money and the time, I would suggest: spark plugs, spark plug wires, replacing hoses and clamps, head gasket, oil pan gasket, belt, clean throttle body and intake manifold, air filter, exhaust gaskets, brake lines, fuel filter, oil change. Probably more you could replace to make it run more efficiently, but I can't think of anything
