1 - 9 of 9 Posts
what size pulley would be better to run with the stage 2 kit 2.8" or 2.9"
2.8 max's out your duty cycle you'd be safe with just the 2.9 unless you upgraded to 60lbs injectors but there are people running 42's with the 2.8 and a tune
yep....run the 2.8 and upgrade the injectors ...dont half a$$ it
Discussion Starter · #5 · (Edited)
i did not know the stage 2 was a 2.8 i thought it was bigger
stage 2 comes with a 77.9mm pulley and that is a 3 inch pulley
Don't do either without a tune. You'll thank me down the road. Take a look at some Stage 2 logs if you want a real scare. lol I wouldn't even think about putting on a smaller pulley then that without a really good tune. Also do cooling mods first. Check your IAT2s with the Stage 2 kit to see what I'm talking about there. That will scare you too. lol
Discussion Starter · #9 ·
well i was planing on getting a menthol injection kit just for that reason and probably a cobra heat exchanger with a dual pass end plate
1 - 9 of 9 Posts
