Hey everyone,
Since this is the base model the guides I found on here don't seem to be working for this. We got an aftermarket stereo and I have to tap the acc power into the fuse box, as is tradition, but no matter what I try to tap it into I cannot get it to only turn on when the ignition is on. Has anyone else experienced this? And if so, what fix did you find? It's the 2005 cobalt 2.2 ltr and it's base so I don't think it will get power to the sun roof or power windows fuse slots
Mine powered on but no sound. U have to tie all 3 power(red) together and run to the passenger side fuse panel. Do u know if the Lt and LS model has factory small amp in the dash? Tie your pink (brake) in with the ground if it's a double din to bypass having to have parking brake to play videos. This is the wire harness I have and the metra and scoche adapters the wires are not where they need to be
Rectangle Font Line Parallel Slope
Electrical wiring Electronic engineering Circuit component Electrical supply Engineering
Finger Networking cables Electricity Electrical wiring Electronic engineering
Font Line Material property Screenshot Parallel
