1 - 1 of 1 Posts
Driving to work with heater on and the passenger side window starts to fog up to where you can't see through it and I smell radiator fluid. I figured that the heater core went out.
Big puddle under car after work, went to auto parts store got 4 jugs of coolant and made it home with two stops to cool down a bit and refill.
check the next day and the drain tube is dripping coolant. Need the car for work so I bypass the heater core and start to remove the heater core cover. Getting the gas peddle off was a pain in the 6.
removing the heater core cover was a huge pain and ended up having to break it off in three places.
Now I have a new cover and need to bolt it on but can't find which bolts to use....anyone know?
1 - 1 of 1 Posts
