Hey guys, I've had this issue a couple times now and can't seem to find a fix. I've found many posts here and on other forums where I've found countless others have had this issue but I can't find a solution.
What I have done is check the g101 ground, which is fine and checked the resistance at the front tire sensor, which was 1100-1250 and from my research, this should be between 800-1350. I don't know what else to do and would much prefer to not bring it into a dealership as I can't afford that.
Any help would be greatly appreciated, and I can provide more info if necessary, thanks!
Edit: Found a fix and after a test drive I had no check engine light, traction control light turned off, back to smooth shifting and no low rpms,
