Discussion Starter #1 (Edited by Moderator)
Hey guys does anyone know if I can take off the cover of the timing chain to see the condition of the sprocket on the crank for the timing chain? I think that sprocket might be bad. I had the chain replaced about 50k miles ago and the mechanic says it jumped time.
Does anyone know if this ecotec engine is a zero interference meaning the vales wont hit the pistons if it jumps time?
The mechanic says i need a new head because the valves hit the pistons but i'm not so sure about that.
Ecotec is an interference motor. Timing chain usually jumps timing because tensionner fails.
Any thoughts about the sproket on the crank? Ever see that go bad?
Do you have any links on how to time this engine, I cant seem to find anything on google.
