Hi
I HAVE A 2008 COBALT AND THE BLOWER MOTOR STOPPED WORKING SUDDENLY, I CHANGED THE END CONNECTOR AND HAD POWER TO THE CABLE GOING TO THE MOTOR ,THE MOTOR STARTED UP ,
THEN PUT EVERY THING BACK ,TRIED TO START THE MOTOR UP ,DID NOT START AND NOW I HAVE NO POWER IN THE LINE GOING TO THE MOTOR
PLEASE HELP !
Check the 2 fuses in the BCM block and maybe the relay but they never seem to go bad.
Hi
thank you for answering ,
what 2 fuses would it be in the BCM Box , were would the relay be located for the motor
Thank you
---------- Post added at 05:54 PM ---------- Previous post was at 04:27 PM ----------
Hi
i found the problem !
Why my blower motor did not work !
The problem was the bcm fuse under the hood in the fuse box,
on the left corner you got 2 on there own bcm 40 amp and 30amp ,
the problem was the 30 amp that looked ok , i changed it
and suddenly got power back to the line ...
Thank you for helping !
