· Registered
I have searched this form and can’t find anything. Brake lights stay on unless you pull the ebrake. Turn signals work like they should. I coated the BCM with die electric grease and the same issues. I pull the wires out of the bcm going back to the light and they go out. This is all with the foot pedal switch unplugged. So I got another BCM same issue. Can’t seem to find the yellow wire and where it goes into the BCM from the foot pedal. But if I unplug the big connector on the back of the BCM it still stays on and if I unplug the J2 connector it stays on. Kinda at a loss at this point any help would be great!
