1 - 18 of 18 Posts
I have a 2010 Chevy Cobalt that came with remote start on it and just recently it started to not work. All the buttons on work except for the start. When i hit the start button the lights flash like it is going to start then nothing. Can anyone help.:thanks
I will do that as soon as i can but the second remote i have does not work either. It does the same thing. The lights flash then nothing.
Ahh. If they both don't work it could be the module that gets the signal from the remote maybe, but again coby will be able to tell you more about that when he gets back on
Sent from AutoGuide.com App
Your FOBs are obviously good. Also any door ajar, or door lock actuator malfunction. Make sure you didn't accidentally disable the start option in the menus.
Trunk and hood ajar will also stop remote start, sorry forgot those.
I don't know for sure about the Cobalt but Malibu and G6 it's one of the menu items. It will read "Remote Start: ON" or "Remote Start; OFF" it should be "ON" Check your owners manual. What the hell....here are the pages from your owners manual. I will highlight in red the paragraph you need.
DIC Vehicle Personalization
Your vehicle has personalization capabilities that allow you to program certain features to a preferred setting. All of the features listed may not be available on your vehicle. Only the features available will be displayed on the DIC.
The default settings for the features were set when your vehicle left the factory, but may have been changed from their default state since that time.
To change feature settings, use the following procedure:
Entering Personalization Menu
Turn the ignition on while the vehicle is stopped.
To avoid excessive drain on the battery, it is recommended that the headlamps are turned off.
Press and hold the information and reset buttons at the same time for one second, then release to enter the personalization menu.
If the vehicle speed is greater than 2 mph (3 km/h), only the UNITS menu will be accessible.
Press the information button to scroll through the available personalization menu modes.
Press the reset button to scroll through the available settings for each mode.
If you do not make a selection within ten seconds, the display will go back to the previous information displayed.
Personalization Menu Modes
OIL LIFE RESET
When this feature is displayed, you can reset the engine oil life system. To reset the system, see Engine Oil Life System . See "OIL LIFE" under DIC Operation and Displays for more information.
UNITS
This feature allows you to select the units of measurement in which the DIC will display the vehicle information. When UNITS appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
ENGLISH (default in United States): All information will be displayed in English units.
METRIC (default in Canada): All information will be displayed in metric units.
To select a setting and move on to the next feature, press the information button while the desired setting is displayed on the DIC.
TIRE LEARN?
If your vehicle is equipped with a Tire Pressure Monitoring System (TPMS), this mode is available on vehicles without the Remote Keyless Entry (RKE) system. After rotating the tires or after replacing a tire or sensor, the TPMS must re-learn the tire positions. To re-learn the tire positions, see Tire Pressure Monitor System . See Tire Inspection and Rotation and DIC Warnings and Messages for more information.
REMOTE START
If your vehicle has remote start, this feature allows remote start to be turned off or on. Remote start allows you to start the engine from outside of the vehicle using your Remote Keyless Entry (RKE) transmitter. When REMOTE START appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
OFF: The remote start feature will be disabled.
ON (default): The remote start feature will be enabled.
See Remote Vehicle Start for more information.
LOCK HORN
If your vehicle has Remote Keyless Entry (RKE), this feature, which allows the vehicle's horn to chirp every time the lock button on the RKE transmitter is pressed, can be enabled or disabled. When LOCK HORN appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
OFF (default): The horn will not chirp on the first press of the lock button on the RKE transmitter. The horn will still chirp on the second press.
ON: The horn will chirp on the first press of the lock button on the RKE transmitter.
See Remote Keyless Entry (RKE) System Operation for more information.
UNLOCK HORN
If your vehicle has Remote Keyless Entry (RKE), this feature, which allows the vehicle's horn to chirp on the first press of the unlock button on the RKE transmitter, can be enabled or disabled. When UNLOCK HORN appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
OFF (default): The horn will not chirp when the unlock button on the RKE transmitter is pressed.
ON: The horn will chirp on the first press of the unlock button on the RKE transmitter.
LIGHT FLASH
If your vehicle has Remote Keyless Entry (RKE), this feature, which allows the vehicle's exterior hazard/turn signal lighting to flash every time the lock, unlock, or trunk release buttons on the RKE transmitter are pressed, can be enabled or disabled. When LIGHT FLASH appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
OFF: The exterior hazard/turn signal lighting will not flash when the lock, unlock, or trunk release buttons on the RKE transmitter are pressed.
ON (default): The exterior hazard/turn signal lighting will flash when the lock, unlock, or trunk release buttons on the RKE transmitter are pressed.
DELAY LOCK
This feature, which delays the actual locking of the vehicle, can be enabled or disabled. When DELAY LOCK appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
ON (default): The doors will not lock until five seconds after the last door is closed. You can temporarily override delayed locking by pressing the power lock switch or the lock button on the Remote Keyless Entry (RKE) transmitter a second time.
OFF: The doors will lock immediately when pressing the power lock switch or the lock button on the RKE transmitter.
See Power Door Locks , Delayed Locking , and Remote Keyless Entry (RKE) System Operation for more information.
AUTO UNLK (Unlock)
This feature, which allows the vehicle to automatically unlock certain doors, can be enabled or disabled. When AUTO UNLK appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
ALL (default): All of the doors will automatically unlock.
DRIVER: The driver's door will automatically unlock.
NONE: None of the doors will automatically unlock. You will need to manually unlock the doors. If you have a manual transmission vehicle, the door(s) will automatically unlock when the ignition is turned off. If you have an automatic transmission vehicle, you can select when the automatic unlocking will occur. See "UNLK (Unlock) (Automatic Transmission Only)" following. See Programmable Automatic Door Unlock for more information.
This screen displays only if your vehicle has an automatic transmission and DRIVER or ALL is selected for the AUTO UNLK feature. This feature determines when the automatic door unlocking will occur. When UNLK appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
KEY OFF: The door(s) will unlock when the key is turned off.
SHIFT TO P (Park) (default): The door(s) will unlock when the vehicle is shifted into P (Park).
EXT (Exterior) LIGHTS
If your vehicle has Remote Keyless Entry (RKE), this feature, which allows the vehicle's exterior perimeter lighting to turn on each time the unlock button on the RKE transmitter is pressed, can be enabled or disabled. When EXT LIGHTS appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
OFF: The exterior perimeter lighting will not turn on when the unlock button on the RKE transmitter is pressed.
ON (default): The exterior perimeter lighting will turn on when the unlock button on the RKE transmitter is pressed.
LANGUAGE
This feature allows you to select the language in which the DIC will display. When LANGUAGE appears on the display, press and hold the reset button for at least one second to scroll through the available settings:
ENGLISH (default): All messages will appear in English.
FRENCH: All messages will appear in French.
SPANISH: All messages will appear in Spanish.
GERMAN: All messages will appear in German.
To select a setting and exit out of the personalization menu mode, press the information button while the desired setting is displayed on the DIC.
Exiting Personalization Menu
The personalization menu will be exited when any of the following conditions occur:
• A ten second time period has elapsed.
• The ignition is turned off.
• The end of the personalization menu list is reached.
Discussion Starter #15
I checked the menu and it says that the remote start is on. When i lock the car the light with the car and lock flash for a long time and when i try to remote start it, the turn lights flash once.
Chevy Customer Service
Welcome to the forum, Helmet. I see you're already getting great input for members of the community here; unfortunately I'm limited in my abilities to troubleshoot being a customer service representative. However, let me know if you have any warranty questions, or if you decide to work with a dealership to get this checked into.
Sarah, GM Customer Service
Unlock and lock your doors then check to see if all doors are locked. If you have a bad actuator the car won't start remotely because it falls into security mode. Technology is great but when it fails it can be a pain.
---------- Post added at 11:22 AM ---------- Previous post was at 11:06 AM ----------
Just remembered if you have a pending code not necessarily a CEL your car will also not start remotely. So check for codes!
---------- Post added at 12:16 PM ---------- Previous post was at 11:22 AM ----------
Just found this, it might help....
Remote Vehicle Start Inoperative
Diagnostic Instructions
Circuit/System Description
Remote vehicle start (RVS) begins as an RF message received by the remote control door lock receiver (RCDLR) from a keyless entry transmitter. The RVS request is sent by the RCDLR to the body control module (BCM) via serial data. The BCM monitors system conditions such as content theft deterrent (CTD), hood ajar status, and body DTCs to determine if an RVS event will occur. If conditions are determined to be acceptable, the RVS message is sent to the engine control module (ECM). The ECM monitors system conditions such as engine control parameters and vehicle theft deterrent (VTD) to determine if engine starting will be allowed. If conditions are acceptable, the ECM will initiate engine starting. During the engine run time in a RVS attempt, before the operator enters the vehicle, the ECM may discontinue engine operation if system conditions require it or a message is received from the BCM requesting the engine be turned OFF.
Diagnostic Aids
Important: If the vehicle has a current vehicle DTC that illuminates the malfunction indicator lamp (MIL), the cause of the DTC must be diagnosed before proceeding with the Remote Vehicle Start Inoperative diagnostic.
The RVS system will not operate if any of the following conditions are present:
• A current vehicle DTC that illuminates the malfunction indicator lamp (MIL)
• The vehicle is in valet mode.
• More than 2 remote starts have been attempted.
• The hazard switch is in the ON position.
• A current hazard switch DTC is set.
• The vehicle hood is ajar.
• A current hood ajar DTC is set.
• The CTD system detects an alarm trigger.
• Excessive engine RPM
• Excessive coolant temperature
• Accelerator pedal position greater than 0 percent
• Vehicle not in park
• Vehicle theft deterrent malfunction
• A current automatic transmission shift lock control system DTC is set.
• A vehicle speed sensor signal is detected by the ECM.
Did you ever figure the issue out?
I have the same issue 2010 4dr just started happening about 2-3 weeks ago. I opened and closed all doors, turned the key in the door lock several times, went through the menu turned remote start off cycled the car on and off a few times turned the remote start back on and nothing all the doors lock and unlock with the key fab.
1 - 18 of 18 Posts
