1 - 8 of 8 Posts
I've got a 07 ss/sc and 5th gear is constantly slipping outta gear but the stick doesn't return to neutral. I have to bring it back to neutral and engage it again, then 2 minutes later it'll do it again, any ideas fellas?
Levee
c s s . n e t
that is what he meant. Search there for your trans.
I wouldn't say synchro sleeve. 5th gear should have ring gear teeth, synchronizer, sleeve, gear, fork, and linkage. If it was a synchronizer sleeve (lol), then reverse would be affected as well, since reverse is the only straight gear on our transmissions. The rest are helical and 5th is sync'd with reverse on sleeve. just like 1-2, 3-4. I would check first linkage, then motor mount/trans mount.
1 - 8 of 8 Posts
