1 - 13 of 13 Posts
Is there a drain tube besides the drain on the firewall that i can try to unclog? Ive tried a thousand times to unclog it but its not working. And why do the cobalts have a double barrel drain from the firewall? There's actually two sides to the drain and I can get in the right side (drivers side) but cant get anything on the left side.
The evaporator drain tube is located on the right side of the firewall, or passenger side. If it’s got debris in it, it will likely have to be cleared from the inside. You will need to remove the dashboard and hvac box and open it up. Unless you can get a super strong vacuum to suck it through, but it doubt it.
The ac drain spout has two “openings”. It’s designed this way to help prevent larger items getting stuck on the ac drain tube. Just stake a garden hose and flush it out, that’s what I did with mine many times.
If you try that but still have a leak then you may need to reseal the ac drain tube where it comes out of the firewall. The foam insulation GM used dries out after some time and will allow water to seep back into the cabin. GM has a TSB on the issue.
Discussion Starter · #6 ·
You mean i can flysh water into my my drain tube and it wint ruin my system?
You can flush it with water using short bursts of water with the garden hose, and then letting it drain out. Too much water and you will fill up the evaporator core and it will start spilling out under the dash, so use just short bursts of water.
I use the air compressor and I The red pistol grip attachment with a skinny pipe on the end from Harbor freight for about five or seven dollars
Sent from my iPhone using Tapatalk
So I'm now here at this point with my car where the evaporator drain is leaking a bit into the floor. I figured it was clogged. It isn't, the air box itself is leaking where its sealed together. Also I was eager to clean the blower motor wheel. Well GM had an interesting design to where you either have to cut the box open from the outside, or take the dash out. The engineer who designed this should be shot or hung, seriously. I'll probably remove the dash and reseal the box. The foam that seals the top and bottom halves is probably deteriorated anyways. Of all things on this car that could've been nice and easy. Because most things are really easy and simple to do for the most part. I notice theres actually holes to screw in a new blower motor. Kind of reminds me of the stupid designs on the Dodge Ram trucks where it doesn't come factory with a filter for the ac, yet has a cutout that you can add a section to make a tray to fit one in.
1 - 13 of 13 Posts
