I just installed my aftermarket radio and now I'm trying to locate a place to install my XM tuner box. If anyone has already done this I would appreciate any ideas on where to install the tuner box. Thank you.
I replaced mine as well. I took out the factory XM box under the rear deck and put my pioneer in its place. Secured it with padded double sided tape on all four corners bith for security and also for shock protection. used the factory antenna too.
Discussion Starter · #3 ·
So let me understand this. You put the tuner box in the trunk and ran the cable from the box to the aftermarket head unit?
Discussion Starter · #4 ·
Ok well I finally got everything where I want it. I ended up putting the tuner in the trunk on the underneath of the back deck lid. Thanks for your tip Polarbair.
