1 - 20 of 85 Posts
Not hard at all. I have two sets on mine. One for the horn and one for the alarm. For the horn. I just tapped into the factory wiring. Just make sure your connection has a water tight seal.
Sent from AutoGuide.com App
Where did you find room for all those horns? Lol
Removed the front bumper. One set on each side. Driver side is cramped because the CAI.
---------- Post added at 11:51 AM ---------- Previous post was at 11:48 AM ----------
How to anywhere?
That I know of no. I've done 6 set of these for friends. Just need to place a bigger fuse to run the horn. Simple 2 wire hook-up.
If you don't mind to write me up one. The set I posted a link for comes with a relay
Discussion Starter #12
The factory horn is located under the driver side head light. There's 2 10mm bolts that hold the light to the bracket. Once removed its easy to access the horn. Unplug the factory connector and tap into the power source there.
Okay I wasn't sure if you did it under the dash. So your just using the factory plug
I have always hated the pathetic "beep-beep" horn that the Cobalt comes with.
Last summer I got these PIAA dual tone horns. Plenty loud at 115dB and they mount on the stock bracket in minutes.
I find the air horns (and especially the train horns) to be very juvenile. But then again maybe I'm just getting old ;-)
Piaa Lighting Sport Horns High Tone 85112 Horn
Discussion Starter #14
Yep. Defiantly old. I laugh my ass off at train horn pranks on YouTube. I just am getting air horns
The stock Cobalt horn is just pathetic. I plan on replacing it with a set of Fiamm AM80 Made in Italy horns. The Malibus and Impalas usually use those horns, but the Italy ones are better sounding.
Discussion Starter #16
I ordered my horn tonight. Hopefully have it done by the weekend. If it ain't to hard I'll make a how to
You could've gotten the Ferrari horn kit haha. I have seen that on a Geo Metro once, could not stop from laughing.
This is what it would sound like and its funny to hear in person.
1 - 20 of 85 Posts
