I just got a new amp for my car...the 5 channel memphis belle, and because of that, I also will need to replace my sub (ohm loads dont match up)
I am selling, as a package for the cobalt the following:
my factory sub box with the memphis 15-PR10D4V2 10" sub installed
I would also include the OEM nuts and bolts to secure the sub for anyone wanting to retrofit this in a cobalt without the factory sub
1 memphis 16-MCA3004 4 channel amplifier
•Compact Aluminum Chassis with Custon Black Pearl Finish
•Gold Plated RCA Connectors
•Full MOSFET Design
•Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
•4-Way Protection Circuitry
•Platinum Finish Wire Connections
•Accepts 4 Gauge Power and Ground Wire
•RMS Power Ratings:
◦75 watts x 4 chan. @ 4 ohms
◦115 watts x 4 chan. @ 2 ohms
•Adjustable Input Sensitivity: 250mV - 5V
•Dimensions: 18.5" L x 7.6" W x 2.4" H
1 memphis 16-MC500D amplifier
•Class D Monoblock Subwoofer Amplifier
•RMS Power Ratings: ◦250 watts x 1 chan. @ 4 ohms
◦500 watts x 1 chan. @ 2 ohms (we had these amps tested when I was selling memphis, peak power is around 1100w)
•RCA Outputs: 1 Pair
•Full MOSFET Design
•Built-In Fully Variable Low Pass Filter: 50 - 250 Hz
•18dB Per Octave Crossover Slope
•Built In Fully Variable Sub-Sonic Filter: 20 - 50 Hz
•Adjustable Input Sensitivity: 200mV - 4V
•Dimensions: 12.6" L x 7.6" W x 2.4" H
I would also include 4 gauge power wire with fused distribution block
4 gauge ground wire with distribution block
8 gauge wire from distribution block to amplifiers
3 sets 20ft RCA cables
Barrel fuse for off of battery
gold plated eyelets for battery connection and ground
asking $500 + shipping for the package, and I could easily walk anyone through the installation on this one if they purchased it, could even do a write up for them
this would work for your factory speakers, but really comes alive with a nice set of aftermarkets (sorry, I'm not pulling my MB Quarts) :)
Discussion Starter #2
I will also entertain offers
Sent from my Autoguide iPhone app
here are the photos of the 4 channel amplifier... as well as a photo of the 2 together
I have posted just the amps up on ebay...but I will end the auction (and have said in the description that I can) if someone on these forums wants the package, I would rather help out someone here
It's not available any longer, I sold the amps seperately, but I will take $300 for the sub box and the American pro amps I posted on another post
