1 - 15 of 15 Posts
I just had to get a new antenna mount since mine on the inside broke while trying to take the antenna off to be replaced (rivets came undone) and I got the 15878187. Does anyone know what size thread goes on this? Is it the 7mm or the 6.0mm? It hasn't come in the mail yet to measure it myself.
I believe it is 7mm...
I believe 07+ has 7mm and lower is 6mm
Sent from my PG86100
The car is an 06. I got a new bracket OEM # 15878187 I need the size of that. The old one doesn't matter. I basically need to verify what size this bracket is since I couldn't tell with the description.
ok i see, but in that case i don't know what size yours would come in. You would have to find it when you receive it, where did you order it from?
If you have an OEM number why dont you call the dealership's parts department and ask what size it is?
yeah i agree, thats probably the best way to find out...
Ok. I was just wondering if anyone could answer it quickly. But I will give them a call in the morning
Problem is we dont know the part just by the number. Maybe you can google the scematic of that specific part number?!
So if it is OEM straight from GM for your 06 and Bronx said it was a 6mm on those then he is probably right.
Discussion Starter #13
Got the scoop from GM.
If you are replacing the assy for the antenna, they only sell the 7mm. You are required to upgrade from the 6mm to the 7mm.
in that case get the 7mm shorty antenna modernperformance.com is a site for it. There's more but that's where i got mine
Halfway through 2006 there were a couple changes to the Cobalt to include the 7mm antenna. There is someone makeing a shorty for the earlier than 6 of 06 now, I cannot remember who though.
1 - 15 of 15 Posts
