1 - 8 of 8 Posts
On the way to work yesterday I noticed my gauge lights and radio ac/heater lights went out. I also found out from somebody at work my taillights weren't working. I still have brake lights and headlights, I checked the instrument cluster fuse and it wasn't that because I still had the odometer info and what not but I don't know if its a relay or what? I only have 6,100mi on an 07 should I just bring it in or try to figure it out?:confused:
I've had that happen to me before, its just a blown fuse.
Its your Park Light fuse in the panel under the hood. just use your owners manual and change the fuse.
Ok well it blew again any idea what could be causing it? I haven't done anything to it for awhile so I wouldn't think I caused it.
Theres a short somewhere in the lines. Most likely the insulation on a wire has somehow worn away. That there is warrenty work. Take it in and get it fixed, or keep blowing fuses.
Well I took my neons out (even though they weren't hooked to that fuse) so we'll see what happens!
1 - 8 of 8 Posts
