1 - 10 of 10 Posts
I wanna change out all my interior lights.. Like the dome light and the trunk light. with blue led lights. does anyone know the part number for these lights? and any other factory interior lights. i have a Cobalt LS 2dr. if that makes any kind of difference
Just spray paint your lights blue with a high temp paint :). Worked for mine
nah.. i know that'd be cheapper probably but i would rather buy actual colored ones.
Print out the list and find them at your nearest retailer.
Certain bulbs are available for sale at the SYLVANIA Online Store. New bulbs will be online for purchase in the coming weeks.
Stay informed about new products from SYLVANIA. Sign up with one of our newsletters and let us help you with your needs.
2007 CHEVROLET Cobalt
High & low beam headlamp
9007
9007SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9007ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9007EB EcoBright - Your Environmental Choice
9007XV XtraVision Halogen - The Brighter Light
9007CB Cool Blue Halogen - The Whiter Light
Parking light
3157LL
Front turn signal
3157LL
Rear turn signal
3157LL
Tail light
3157LL
Stop light
3157LL
High mount stop light
912
912LL Long Life Upgrade: Up to twice the life of the standard lamp
Fog/Driving light
H11
H11ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H11XV XtraVision Halogen - The Brighter Light
License plate
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Back up light
921
921ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
Rear sidemarker
194
Map light
2825LL
Dome light
562
Step/Courtesy light
212-2
lol thanks for all the part numbers but i only wanted the ones on the inside of the car and the trunk. haha. so 562 i the dome light inside where you sit. would the trunk happen to be the same?
trunk light is a 194.
i bought mine off of Vleds.com
same thing for the license plate bulb
bought the license plate bulb and it came with 2 so i put the other one in the trunk.
V-LEDS HID WHITE 6 LED M-SMT FLANK BULBS 194 168 158 2825
(for trunk and works for license plate bulb too)
HI POWER 3 LED WHITE DOME LIGHT BULB 561 562 564 212-2
watch out for the install
i installed mine and the light went back and forth because its not a tight fit like the oem light so whenever i closed my door the light would move and it would go off and back on due to the impact of the door closing.
a member on css said to bend the terminals. i did and i blew fuses and it doesn't wanna work with the led one with out burning fuses. i replaced the fuse and it worked but it didn't wanna stay in tight. so i put the stock bulb back in and it doesn't fit tight. sometimes the light goes out. and i might have to replace my whole dome light housing if it keeps getting messed up
i was hitting hard with my subs and the light would flicker due to the terminals being bent and the light being loose due to that
hope this helps man
i can post pics of the trunk light and the license plate light if you wanna see what the white looks like
looks good imo i just wished i could use the dome light.
1 - 10 of 10 Posts
