1 - 1 of 1 Posts
ARK Performance Inc. was founded 15 years ago, and is now one of the largest leading manufacturing facilities in the Republic of Korea for aftermarket performance products. Since the beginning, our main goal is to design and engineer high-end quality products that are reliable and proven for all types of professional motorsports.
At ARK Performance, we are devoted to offer you new and trend setting exhaust systems, suspension parts, engine parts, CNC machined products, and body exterior parts, that will always be superior in performance, design, and craftsmanship using advanced innovative technology. With the experience, knowledge, and passion, we are committed and value our customers and the industry with nothing but the best and up to date products.
DT-Exhaust System
The ARK Exhaust System is committed to leadership, technological innovation, and supplying the best quality performance exhaust products in the automotive aftermarket. Today, those efforts have earned ARK position of being the best and one of the largest sport exhaust manufacturer. The sound of a ARK exhaust system is as distinctive as the performance gains it makes, so it is imperative that the acoustic signature be 100% ARK.
The ARK DT-S muffler has a warm exhaust sound at idle and a robust full-throttle note. All ARK Fabrication Performance Exhaust systems are 100% T-304 stainless steel mirror polished, all tubes are precision mandrel bent and everything is hand TIG welded featuring 12month warranty. Additionally, No other company has devoted more time to sport exhaust sound results. Deep, throaty and rich. That is the sound of ARK. You are going to love the fit, finish, and performance of your ARK exhaust system. And the sound is going to turn heads, including yours. They are a direct replacement for the original equipment - no cutting, welding, or modification is required. Installation was a snap because it all lined up just like the stock system.
Cobalt - 05-10 - - LSJ supercharged I4 - 2.5" Piping - Double layer Polished Tip T-304 POLISHI S-STEEL System
N-II Exhaust System
The factory exhaust system of all cars restricts airflow, sacrificing power for sound. ARK's pursuit of perfection led us to design a system that increases the speed of exhaust exiting your engine, thereby allowing for less backpressure. The result is reaching your engine's potential for increased power, torque, and response, all without sacrificing sound quality.
All ARK exhaust systems are engineered with performance, quality, and value as our main goal. Through extreme efforts from our R&D teams, we have maximized all airflow and power through dyno testing and tuning, while maintaining reasonable sound levels for street use. ARK Exhaust Systems all retain all factory emissions equipment and conform to the California Vehicle Code 95-decibel exhaust noise (Note: Some ARK exhaust systems require a removable silencer). Each ARK Exhaust is designed specifically for your car. What works on one car may not be optimal for another car. Therefore we meticulously test each system to make sure everything is perfect.
Each ARK system features high quality mandrel bent, SUS T-304 polished piping, which allows for the smoothest exhaust flow throughout the system. Piping diameter is also important to the optimal exhaust flow and power gains. Because of the consistent pipe diameter in all the bend areas from the mandrel bending process there is less restriction and turbulence which increases exhaust flow velocity and worded a bit different.
Cobalt - 05-10 - - LSJ supercharged I4 - 2.5" Piping - 4.5" Angle Cut Polished Tip T-304 POLISHI S-STEEL System
DT-P Coilover Systems
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The ARK system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride. The ARK DT-P Coilover system has been designed with professional road racing in mind offering extremely high value and performance.
Cobalt - 05-10 - - LSJ - Height/Ride Adj - Spring Rate - Front: 8kg/mm Rear: 6kg/mm
ST-P Coilover Systems
ARK Performance brings ground-breaking finest quality damper kits that give defined comfort and balanced corner handling. To sophisticate our drivers without loosing their performance results, ARK damper kits offer diverse series adaptable to specific driving conditions. ST-P Series, designed to adapt to all of your driving conditions, will create the harmony between power and stability which you demand. The full length adjustment system gives you the freewill to place various set-ups to meet your needs for specific road conditions. Hard rubber upper and lower mount designs in ST-P series absorb noises as well as vibrations to allow the cabin for quiet operation while still offering flawless suspension proofing.
Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 16 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
Cobalt - 05-10 - - LSJ - Height/Ride Adj - Spring Rate - Front: 7kg/mm Rear: 6kg/mm
GT Series Lowering Springs
Note: Vehicle drop rate is based on the model and option of the test vehicle, and may vary based on each vehicle condition, and equipment option.
Cobalt - 05-10 - - LSJ - Lowers - Front: -35mm / Rear: -40mm -
Short Shifter
ARK Performance Inc. Discover true performance driving with ARK performance shifters. ARK performance shifter allows drivers to feel the control over their ride handling and performance, while its unique design offers most authentic tuner experience.
All the driving excitements begin with engaging the first gear. Gear shifting is the important key when maximum control over your ride. The positive feeling of your hand ensures the precise engagement of gears. It's all about when it comes to true performance driving is getting the right gear.
Most factory stock shifters are not designed for racing environment rather suited for everyday driving. For performance driving you should have a precise engagement of shifter for maximizing control over your car while it reduces shift travel or shift throw for fast gear acceleration without losing forward momentum. So the racing isn't very exciting until you equip with a right performance shifter.
ARK performance shifter offers durability and precision with high grade material, T-303 stainless steel, AL2024 aircraft-grade aluminum ( Stronger than AL6061 grade), and precision steel bearings for last long. ARK shifters are manufactured using the latest CAM-controlled machining and milling equipment for precise products and designed replace minimum key parts to bring a simple straightforward installation.
Cobalt - 05-10 - - 2.2L - Knob Included - 38%-35% Throw Reduction
Cobalt - 05-10 - - 2.0L - 5speed - Knob Included -
GO TO NOPI ARK PERFORMANCE Catalog for model specific images and details
Contact the salesmen below or PM me for our best deal on ARK PERFORMANCE Products
1 - 1 of 1 Posts
