So someone tried to steal my car last night...I see they damaged around the lock cylinder and inside where the key goes... Is there any way I can remove the cylinder and get the key to turn? I don't care if I have to take all the pins out, I just really need to drive this car!!
---------- Post added at 01:25 PM ---------- Previous post was at 12:28 PM ----------
Fixed my own problem: I put the key in the ignition and then I got a vice grips and attached it to the outside of the cylinder...gently turned it until it went to the acc position. Then I used the vice grips to turn it back, and after that it's back to normal!!
If people weren't dickholes, you wouldn't have had to do any of this.
Way to fix it yourself though! Just sucks you had to.
