1 - 16 of 16 Posts
Hello. HS anyone been able to do anACCEPTABLE audi style led install on a headlamp (stock) without having to open them? If so can you describe and post pics if Available? Thanks!
Levee
The only way I could see someone being able to do this without opening the headlights, is to remove the headlight, and drill the holes for the LED's and do it all that way, however, doing it that way will put plastic drill shavings inside the headlight and would make it not look so good.
As of right now, I would say that there is nobody that has ever (or will ever in my opinion), try to make an audi style LED light setup on a stock headlamp housing without opening the housing up. It only makes sense to open it up, and it's not hard to open them up anyways.
I've seen them, obviously were opened. Good luck doing it without!
Levee
I know it's not the same car, but it's the SAME process here to help pull apart headlight lens' from the plastic backing:
Page 8 is where it tells how to use the baking method (which I have personally used to my success before):
http://www.ricks2k.com/info/instructions/diffuser.pdf
Another method to doing this is to use HOT HOT HOT water (basically boiling water), and pouring it over the lens around the seal to heat up the glue so you can separate the lens. I have never used this method but been told by many that it works well.
Just remember if you're going to do this, to make sure you clean out as much of, if not all, of the old glue in there before putting new glue in, and make sure you use a good strong sealant and make sure the ENTIRE lens is sealed or you will fog and have water enter the light. Not a hard process to do this, just take your time to make sure it's done right. :)
I'm saying an led strip. This video advertising a product must have been lying to me then because in showed them slapping down a strip over top the headlight. I gues what I'm saying is there room on top or below the headlight to place the strip where it won't look too junky? A guy on here did it but this was long before I joined this forum and by then the photo had been deleted from photo bucket as usual.
Levee
I saw a guy with an EVO do this in person. Honestly I thought it looked tacky and rigged that way. I wouldn't do it. I'd do it right if I did it at all.
Leveecius is right.
Not trying to be abrasive but slapping an LED strip on the outside of a headlight lens looks tacky. The right way to go about it is to open the headlight housings and find a way to secure the strips inside the headlight. Then you have to find somewhere to run the leads out of the housing. I did this with my old housings on my car a while back, what I ended up doing was buying a metal duct clamp at Lowe’s, flattening it, adhered the LED strip to it, then used epoxy to fasten the assembly to the inside of one of the reflectors. The reason I couldn’t slap the strip anywhere inside was because the reflector bucket was curved, and nothing looks worse than a sagging LED strip.
I can post some photos if you’d like.
The only reason why I don't want to do it the "real" way is because of my fear of not getting it to seal up correctly. That's one of the most terrible things that can happen to a cars appearance.. foggy hazy headlights. One of my headlights had to be replaced under warranty because of that. It seems hard for cars to retain that sealing capability around the lights. If the people at the factory can't do it right I sure as hell know ill mess them up.
Levee
Get some clear marine rtv sealant. There is a glue channel around the entire lens. Fill the channel completely around the lens. Put the lens on the headlamp backing making sure all parts of the channel seat correctly. Let sit for 1 hour before allowing to be tampered with or re installed. Super simple to not mess up. Factories get bubbles in the glue thus not sealing all the way. That is one thing a machine can't catch that a human eye can.
ew. Don't do it, looks tacky. Like christmas tree status.
But seriously if you do decide to do it, just do it right. Otherwise I wouldn't bother. Headlights in the oven at 265 deg F for approx. 7 minutes. Then do your mod. Then back in the oven for 5-7 minutes, push the lens back on well, and if still scared, go around the whole headlight seam with clear silicon. I've Opened my headlights like 3 times, did this, never got any condensation whatsoever.
Other than the original stock audi's and the new Jaguars, I have yet to see an LED mod in person that looks nice. I have seen VERY few nice LED mods online, but those were done by professional retrofitters with good taste and didn't overkill it.
Discussion Starter #11
What would I set them on when placed in the oven? Won't they get damaged on the areas that make contact with whatever they set on in the oven, whether a tray or rack? I mean they have to exhibit some melting at those contact points am I correct?
Levee
You can use a wet towel, that's what I've done before.
no, they won't, especially at that temperature.
Best pic i could find of my old Sable:
Stuck 24" led strips under the headlights double sided outdoor taped to the body.
Now the problem is, i did the same thing to my cobalt and it looks retarded because the body line curves up so they arent flat.
1 - 16 of 16 Posts
