Up until last week, my auto lights worked just fine. This week, the auto-lights have the headlights always on and the dash in dim night mode no matter what the surrounding light is. I can still manually turn the lights off with the switch, which returns the dash to day brightness, but when I start the car, the headlights come on and the dash goes dim. During the day it is very hard to see the coolant temp or milage. Not a huge problem but annoying.
Anyone know where to start? Is there a way to check the light sensor on the dash? - The sensor isn't covered by anything, the windshield is clean and the brightness rheostat is adjusted all the way up.
Thanks.
Not ignoring you just trying to figure where to start. I believe sensor goes to "BCM", let me look it up for you.
---------- Post added at 12:13 AM ---------- Previous post was at 12:07 AM ----------
Yes, pin 44 and 47 of P2 of the "BCM".
---------- Post added at 12:13 AM ---------- Previous post was at 12:13 AM ----------
Now to find the schematic.
---------- Post added at 12:20 AM ---------- Previous post was at 12:13 AM ----------
Circled in blue is ambient light sensor, circled in red pertains to DRL
---------- Post added at 12:27 AM ---------- Previous post was at 12:20 AM ----------
Maybe you have a bit of corrosion in the pins, try unplugging "P2" from "BCM" and replugging. Disconnect battery first before attempting this.
Well, so far so good. Did as you suggested. Daytime mode is back, atleast for now. Will update if it happens again. Thanks you!
Good to hear. Hope you did it several times to make sure the contacts were good and clean.
