HI Im new to this ,I just got a 07 Cobalt with a 2.2. And there is a bad drain on the battery, New battery, 5 amp drain , I all ready pulled the fuse's one at a time and got no change. The only way it changes is if i pull the 50 amp fuse in the trunk,and disconnect the the 2 positive cables off the jumper post under the hood at fuse box, and if i hook either one back up the 5 amp drain comes back
any help would be greatly appreciated
The 50 amp fuse B+ in the trunk goes to the BCM. The 2 wires on the boost post are one from the battery positive terminal and the other goes to the starter.
any thought is to why either would cause the drain
---------- Post added at 10:29 AM ---------- Previous post was at 10:06 AM ----------
any thought as to why either would cause the drain
Your going to have to trace it I'm afraid.
