1 - 20 of 21 Posts
some balts that have factory 15's run 195/65/15
balts that have factory 17's run 205/50/17
balts that have factory 18's run 225/40/18
if you go to Tire Rack - Your performance experts for tires and wheels and look at the specs of these tires, they all have a 25" overall diameter. you want to stay with that diameter as close as possible to keep your speedometer accurate.
---------- Post added at 08:08 PM ---------- Previous post was at 08:08 PM ----------
you can also mess around by getting wider tires with a lower side wall ratio and end up with that same 25" diameter.
---------- Post added at 08:10 PM ---------- Previous post was at 08:08 PM ----------
for example cobaltxfe09 said he had 215/45/17. those are about a 24.6" diameter so that is pretty close to factory size
stock tire size is 195-60-15's the 65's are too tall, look rediculous.
use 215-45-17's and you wont regret it... i used goodyear eagle gt's i still got 3 of them left. 2 are like new because they just rolled on the back and one i drove on for 1500 miles, the other front one blew when i hit a pothole. pm me if you want them. i just want them out of my garage really
on some balts that is the stock size. not on my XFE though. they are 65's
little off subject but my bolt pattern is a 5x110 but ive also seen some people on here puttin on 5x100. wats the deal? will a 5x100 really fit?
225/45/17 Falken Ziex 512. Really good inexpensive tire. I used to work for discount tire lol. So i know my tires D:
just found a set of 225/55/18 brand new pirellis for $275!
1 - 20 of 21 Posts
