Hello, I'm planning on painting my interior pannels this weekend, but I was hopping for suggestions as to what I need to do to prep it and what paint I should use. Thank you
Cleaning materials
Sand Paper
Krylon Fusion for plastics
Clear Coat
Painters Tape
Clean it, sand it down with fine sand paper,
spray it with about 5 coats or so of Krylon fusion for plastics,
spray it again with clear coat a few times for a glossy finish.
Let it sit for a few hours. The longer it sits, the better!
Cleaning materials
Sand Paper
Clear Coat
Painters Tape
Follow this method, except make sure you clean it again AFTER you sand it. and in between every 3 coats, sand it smooth with some 1000 grit sand paper. And at least 2 coats of clear after the sanding..
