1 - 1 of 1 Posts
I have a 2010 Cobalt that I've owned for about 7 years with nary a problem except a replaced battery last spring.
But I had a couple of codes recently. The car was doing a click over start up, would run for a little bit, and die on me with no sound at all, it would just shut off. Often while breaking or suddenly breaking or starting to accelerate from a stop. Codes had me swap out the Camshaft Position Sensor Intake and Exhaust and the Crankshaft Position Sensor. What did that do?
P0016 Crankshaft Position (CKP) - Intake Camshaft Position (CMP) Correlation- ECM
P0341 Camshaft Position Sensor Circuit Range/Performance
P0365 Exhaust Camshaft Position (CMP) Sensor Circuit ECM
P0366 Exhaust Camshaft Position (CMP) Sensor Performance ECM
The car currently has a tough time trying to start on the first turn of the key, refuses, but will start the second time. Did I miss something, cause something new, or not finish something? I need to get smogged pronto and that's not happening right now :/
Thanks!
1 - 1 of 1 Posts
