1 - 8 of 8 Posts
Look at your door and see where the stock panel runs to if it only goes to the end of the first door it probably wont work and even if it did work would require some cutting. If your stock panel runs further back than just the front door then you have a chance that it will work, the coupe has longer doors and that panel runs the length of them (I should know as I replaced mine with black ones).
I can't garuntee they won't fit if u cut them up
But they def wont fit as is, and you'll b short the other 3 pieces of the lower trim
Yea the black was in the ss sedan cause before I start the swap and was looking into all the parts were out of an ss
1 - 8 of 8 Posts
