1 - 9 of 9 Posts
Hey guys, ive run into this issue with my boost gauge fluttering. When i get on it the needle will bounce around +/- 5 psi and you can hear it from the car too so i dont think its just the gauge. Itll flutter then seem to stop for a brief second at around 6psi then start doing it again. It started happening recently after flashing a tune file from Trifecta, could it be tune related? Any help would be awesome since most of the stuff on google seems to be related to other cars and setups. Thanks guys!
It's probably back pressure. Does this happen if you floor it at a low rpm? It usually happens if your blow off valve or bpv doesn't release enough pressure. You may need to upgrade that.. It's probably tune related if you recently got a tune. I'd contract whoever tuned it and ask about it
---------- Post added at 08:07 AM ---------- Previous post was at 08:04 AM ----------
https://youtu.be/nCj6Spwl1CU
---------- Post added at 08:09 AM ---------- Previous post was at 08:07 AM ----------
That's the surge (pressure) I'm talking about. It's very bad for your engine. If it's just the small flutter you get after revving it's fine. If it's while your engine is under load I would really look into it
---------- Post added at 08:11 AM ---------- Previous post was at 08:09 AM ----------
https://youtu.be/jEUWEsqoWz8
---------- Post added at 08:11 AM ---------- Previous post was at 08:11 AM ----------
There's another. Which is usually the bov not releasing pressure correctly
Yeah it happens if i floor it at low rpms, and if i slowly go through the rpm range. Ive seen both thise videos and it doesnt sound like that. Ill take a video of it later so you can see what im talking about. Yeah ima send them a message and see what they did with the tune. Ive had some people tell me it could be a bad wastegate too though so im not sure where to start.
Hmm.. I think I might know what you're talking about. Make sure your filter is on tight. My car was doing it too but when I checked the filter slipped off my intake tube. My car makes a fluttering type sound too, but boost pressure doesn't bounce. So I'm not real sure what yours is. I would guess it does have something to do with the wastgate or bov/bpv
---------- Post added at 08:33 AM ---------- Previous post was at 08:26 AM ----------
Get ahold of your tuner and then let us know what you find out.
Thanks for the help! Im at work right now but ill check that when i get off and see if thats it and ill upload the video i have of it fluttering. I sent trifecta a message to see whats up with it.
Sorry didnt see i uploaded it private, i fixed that so you guys can see it
It sounds to me like something is being restricted. Have someone rev up your car while you check the hoses and pipes in the engine to make sure none are weak and collapsing in when revved
1 - 9 of 9 Posts
