So I just have a small question that may or may not be a problem, idk.
So I've noticed that whenever I compress the brake pedal on my car all the way and then release it there's a little squeaking noise once I release this, what is this? Not sure if it's something to worry about cause it's something that's happened since I bought the car in August.
The actual brakes do that or the pedal? If its the pedal put some WD-40 or equivilant spray lube on all moving parts of the pedal assembly.
If its the brakes themselves, I dont know.
Take the brake pads off and use ceramic brake lube on
the back side of the pads and lube all of the slide bolts.
Should cure you squeek.
Must have been lost in time then cause I didn't see it.
And yeah it's the actually breaks themselves. Thanks for the advice, I'll be sure to try that
