i had a no start condition at the gas station today.
pulled codes:
p0366 - cam sensor 'b' performance range
p0365 - cam sensor 'b' circuit
and some misc. pump code.
i was wondering if anyone has experienced these codes, because i have all the tools to fix this, just not the knowledge to diag it properly.
The no start was probably caused by a stuck open purge valve causing all the fumes from you filling up the tank to flood the intake. The codes you have is because your engine probably turned backward for some reason. Either from a back fire or diesel effect. Did it start like 2 minutes later?
yea it started after i cleared codes from it be the one for cam range came back. also my fuel econ went down. it went from 600+km per tank to about 400km.
What kind of kilometers on the odometer?
it's at 134,00. replaced spark plugs due to a blown out plug, had to helicoil it. also one new coil pack on the #4 cyl.
