1 - 10 of 10 Posts
I can not break loose the bolt holding the passengers side seat belt. Is there anything that I can put on it to loosen it?
try working the bolts back and forward, tight/loose/tight/loose. they are prolly either seized in there, or they put loc-tite on the bolts(which is common)
Ive tried both ways and it literally bent the prongs on the star shape bit. Loc-tite is on them i know that for sure
heard someone say loctite can come off with heat.
yeah, but he's working on the INTERIOR, so he prolly doesnt wanna scorch his carpet
well yeah, but you could use a blow dryer. it may not get it hot enough to completely loosen it but maybe it'll get it enough to let em work it out
Ill try using some heat on it. Im trying to take it off from the top of the belt anyways...
1 - 10 of 10 Posts
