1 - 18 of 18 Posts
In the lower rpms the car will bog and jerk rapidly and then once it hits like 3500 rpm I have the "turbo spool" sensation. My muffler hanger broke so I just took it off at the axle is that bad? It's done this before even with the tusdo muffler. Car is stock accept for custom short ram and catback. No cel on dash.
Discussion Starter #2
Bump? Lol I also smell a lot of sulfur
Thanks ill check it out. Probably bad secondary?
I think he is refering to the entire cat, not just a o2 sensor.
Yes, because the rear o2 sensor would pick up the failure of the cat.
I meant the second cat. I have 2 of them a primary and a secondary. Oh and these symptoms come and go
Discussion Starter #12
my car has 2 cats one before the secobd o2 sensor and an after cat after thr last 02 sensor. I also have sai
why does your car have these 2 cats you speak of? i only seen 1 on mine, i have SAI too but that only matters when it comes to Header or installing an intake
Levee
My SS had 2 Cat's on the DP. Just get a new DP with a high-flow cat and you'll be fine. It's much cheaper than trying to pay for 2 cats to be replaced. If your secondary Cat is bad, it's because your primary is bad too. If it's just the primary, that means your 02 sensor could go out at any time. It's better just to replace fully :)
i still dont know where the second kitten is:unsure:
eh, illl take that
Discussion Starter #18
yeah I just got the hars core veraion >.< zzp??
1 - 18 of 18 Posts
