1 - 10 of 10 Posts
So it all started on a very cold night about two weeks ago. My car is kept in a garage every night, but on this night i was staying at my girlfriends so it had to manage to spend the night out in the 30 degree weather. When i got up in the morning and was just about to leave for work, my car wouldnt start? Hmm... weird ive never had to jump my car in the long year ive had it. So that night i put the car in my garage, and around 11pm my dad calls me up and says my fog lights are on. I thought this was strange since my car had been off for several hours and i had made many trips out to the garage not noticing anything. I couldnt turn the fog lights off just by pressing the button so i started the car(which surprised me) and then the turned off. The next morning i had to get another jump. I stopped using my fog lights, and for a couple of days my car worked fine. Last night i turned my fogs on just as a test. Everything worked fine on my way home from work. AFter i got home i drove to pizza hut to get food with my girlfriend, then i realized my right headlight is not working. I got home and put it in the garage. Later that night(around 11pm again) my mom said my cars lights were flickering and whatnot, but i was not in a good mood so just ignored it till this morning. Car doesnt start again. i am charging my battery right now. When i first hooked up the charger it said my battery was very low, but now after a hour its got a full charge? My dad said this is not right, because it would take hours for a dead battery to charge full. Is it just a bad battery with bad cells? Or could it be my alternator? Whats going on? Will i ever be able to use my fogs again without draining my battery. I do have hid's both on my heads and fogs by the way.
1st thing is to address the simplest thing. Take the battery to an autoparts store and have them check it for bad cells.
I think i might have fixed it for now... we'll see though. I took off my fog light hid's and put on the stock lights. When i was doing so i noticed the bolt on my fuse box holding down the power cords was a little loose. I took off the power cord for my hid's and then tightened that baby down. So im gonna use my fogs all day today and then see if my car starts up tomorrow morning. If not i will be takin my battery in like you suggested Will mpg. Thanks guys
Could be a bad fog light relay? Maybe the HIDs pulled too much current and damaged the relay. I'm taking a wild guess here.
wow, you have the dreadful "demon car" that every shop hates to work on lol good luck on getting it fixed though
You could also check your wiring and make sure nothing has rubbed so badly that the wires are grounding out somewhere....
Yeah agree with the grounding issue, check all grounds. Have autozone preform a load check on your alt, and battery. If the alt, and battery checks out then check all the grounds going to those lights. If all look good and there's no issue with them, then it could be a relay. My nephew has the same problem on his 1992 Chevy C1500 we replaced all the grounds, the alt, the battery, and even all the relays. Come to find out it was his headlight switch, the highs wouldn't come on but the lows would, then when the highs did come on it would black out all his lights.. the switch was grounding out because it had a short.
1 - 10 of 10 Posts
