1 - 12 of 12 Posts
When I accelerate in my cobalt the car seems gut less. The car will rev up then down a bit then accelerate.
I am not sure if it the clutch or something electrical. It will rev up about 500 rpm then drop down. Then accelerate.
Info of your car would help....model and what not...
Levee
clutch starting to go. put vehicle into 3rd while stopped, let out on clutch as if you were dumping it. if it dies immediately its something else. if it chugs and tries to stay running your clutch is bad.
A few months ago I was also getting a check engine light that would pop on and when checked said something about the throttle. Would this likely be causing the problem? The throttle position sensor or something?
Discussion Starter #12
The car has been giving me a Mass Air Flow sensor error. The car also has a hard time starting some times. Such as when I crank it over it wont start and stall. Then some times it would try a few times and start. Its acting as if its out of gas, but its not.
1 - 12 of 12 Posts
