1 - 12 of 12 Posts
i installed a cold air intake on my car a few weeks ago, and since then my cel has been going on and off. i took it to my school and the scan tool said its running to lean. will a tune fix this?
this is a common issue. I've heard to disconnect the battery and reset the computer so it can learn the new set up but it doesn't always work.
Sounds like a MAF sensor problem. Did it get dusty/dirty when you installed the CAI? Is it reconnected properly?
Check the MAF and clean it off... See how it performs and what brand intake did you go wiht ?
Fujita intakes are known for this issue quite often and it is said that fitment is another common issue with their product. Have you run into that also?
Is it an oiled filter or dry filter? The oiled ones tend to cause issues more often then the dry ones.
Discussion Starter · #10 ·
its a dry filter. the first time my cel came on i looked at the filter to see if it had any water damage and it dident. so idk whats going on with it.
What is the CEL number? Is it the same after cleaning the MAF?
Discussion Starter · #12 ·
i forgot what the number was, ill take it back to autozone sometime this week. i dident clean it yet, the weathers been really shitty the past few days
1 - 12 of 12 Posts
