1 - 8 of 8 Posts
I have a 2008 Chevrolet Cobalt. The two air conditioning vents in the middle of the front are not blowing air at the same rate as all the other vents. All four speed settings work fine on the other vents but not on the two in question. Could this be a motor issue, or could something be caught in the vent area preventing the air from going through? I just noticed the problem today but don't recall there being a problem before today.
Had the same problem with my 06 coupe. A piece of foam rubber came off a piece of the HVAC system that directs air flow. Was fixed under warranty.
Unless you drive the balls off the car, it should be a warranty fix for a 08.
I have a similar problem, only I barely feel ANY breeze from the vents unless I am 6" away from them. I have the fan on 4 but when I sit back, I cant feel ANY air.
check cabin filter... im pretty sure the 2inches of buildup on mine killed my hvac motor at 160k miles
I replaced the cabin filter. The center left vent is pushing more air but the center right is still dead. So there is some progress...
1 - 8 of 8 Posts
