1 - 1 of 1 Posts
Hello,
The ac compressor clutch of my 2008 Chevy Cobalt LS doesn't engage.
I connected two leads one to the positive and one to the negative battery terminal and the other ends of the wire leads to the electrical connection contacts by the clutch. This did not cause any click sound or cause the clutch to move in and out.
What I also did was with a digital multimeter I connected on lead to the battery and with the second lead I check the two electrical contacts inside the electrical connection for the clutch. The first contact showed no voltage and the second 12.5 Volt.
That means that I have to change the clutch? The clutch is the problem?
1 - 1 of 1 Posts
