1 - 20 of 48 Posts
ok so today i down shifted to third because i was goin around a pretty sharp turn i wasnt goin the fast so i didnt rev match but when i did down shift my car stalled out, i started it and drove it home just fine then when i got out the car i noticed the fans where still running with the car off but would eventualy turn off second is when i went back outside to move the car i noticed my check engine light was on and my boost gauge is all wacked, the code the the CEL is P0098 IAT voltage high or somthing like that.... how do i fix this
Levee
your cooling fans will stay on regardless if the key is in the car or if it is running. They are automatic. Your boost gauge is electric, not mechanical. Disconnect your battery for 10 minutes and plug it back in to reset it, and go from there.
Levee
There are cars that are known to do that. That's why there is a warning label for them that says they can turn on at any time, and I have seen cars that do that.
that is true i forgot about those. thought it was because the CEL because thats the only time its done that and also the first time ive seen a cars fine working with the car off and keys removed
Levee
Right, well if the CEL is throwing an AIT voltage too high, that would mean the AIT is going to be reading higher than what it really is, thus making it seem the car is hotter than it is and would turn on the fans.
Levee
LOL, you're right. I am thinking CTS, my bad. I'd still reset and see where it goes from there.
Cooling Fan Control 2.2L (L61)
The engine cooling fan system consists of one cooling fan and two relays. The cooling fan has 2 windings in the motor, one winding is for low speed and the other winding is for high speed. Voltage is supplied to the relays from the 30 A cooling fan 1 and 30 A cooling fan 2 fuses. The engine control module (PCM) controls the low speed fan operation by grounding the cool fan 1 relay control circuit. When the cooling fan 1 relay is energized, voltage is delivered to the cooling fan low speed winding. The PCM controls the high speed fan operation by grounding the cool fan 2 relay control circuit. When the cooling fan 2 relay is energized, voltage is delivered to the cooling fan high speed winding. The cooling fan motor is grounded through its own ground circuit.
The PCM commands Low Speed Fans ON under the following conditions:
• Engine coolant temperature (ECT) exceeds approximately 106°C (223°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off, the ECT at key-off is greater than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The PCM commands High Speed Fans ON under the following conditions:
• ECT reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set
Could you post same info, but for 2.0 SC? That is what you have right Derek?
I would love to help but need year...
Cooling Fan Control 2.0L (LSJ)
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood junction block. The ground path is provided at G105.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the cooling fan 1 relay coil, closes the relay contacts, and supplies battery positive voltage from the cool fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the cooling fan 1 relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the cooling fan 2 relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the cooling fan 2 relay coil is energized closing the relay contacts and provides battery positive voltage from the cool fan 2 fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
No problem, looks pretty much the same.
Discussion Starter #19
Ya it did, the fans are on everytime I drive now even as soon as I start the car the temps r down so I wounder if I need to change the switch
Fan will come on if A/C is one.
1 - 20 of 48 Posts
