1 - 8 of 8 Posts
My check engine light came on this morning, the only thing I can think it might be is my oil life is at 39%.
Does the engine light come on when oil life is below 40%? Or am I going to have to head to the shop?
I haven't got a manual so I can't read about it.
No, it wouldn't come on for 39% oil life. Just go to Autozone and have them use a code reader. They won't charge you anything. It could always be something as simple as a loose gas cap.
yep, autozone will let you read the code for free and then go from there...tell us what is and see if we can help
Take it to an autozone, advanced, etc.
i always make sure i get four clicks outta my cap before i start the vehicle after the dealerhad it, or i filled up
Well it threw a code P0420. Says it's a catalyst efficiency low-bank 1.
Could be either a bad catalytic converter, engine misfire, vacuum leak, or oil leak into exhaust valve guide seals.
So, it's going in on Monday for a check-up.
1 - 8 of 8 Posts
