1 - 20 of 26 Posts
Chevrolet Cobalt License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Cobalt. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to Diode Dynamics' LED, you can easily add this luxury look to your Cobalt!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Cobalt looks at night.
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of OEM! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Chevrolet Cobalt).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Diode Dynamics: 2005-2010 Chevrolet Cobalt License Plate LEDs
194 Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Is this offer still valid? I'm thinking of buying a whole kit, and free shipping would definitely be appreciated! :bigsmile:
Will these work with the Ions as well? And do you guys offer dome lights? May be interested in some if they work. Or I would even be willing to test/send my bulbs in for you guys to do something for the Ions if that is something you would be interested in.
Discussion Starter · #7 ·
We have bulb replacements available in every major size. If you send an email to: [email protected] we can help you find LEDs for your Ion
Thanks!
Nick C.
Discussion Starter · #18 ·
Discussion Starter · #20 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
1 - 20 of 26 Posts
