1 - 9 of 9 Posts
Short Shifter DIY
2005 and up Chevrolet Cobalt
So in order to make installing Short Shifters even easier, we have decided to post up a DIY here on the forums so that you can all see how easy it is to install one yourself!
Begin the installation by parking on a flat surface, as you will have to engage and disengage the hand brake and shift from gears to neutral. If you cannot do so and are obliged to install the short shifter on a slightly inclined surface, place wooden blocks in front or behind the wheels to prevent the car from moving while you’re working.
Estimated Installation Time: 120 minutes
Tools required:
-Flat head and Philips head screw drivers (large and small)
-Needle nose pliers
-Ratchet and extension
-13mm socket and 7 mm socket (or 7mm nut driver)
-6mm or ¼” Punch
-Hammer
-Dremel tool with a multi-purpose cutting bit (strongly recommended)
-Eye protection – safety glasses
-Work table
-Bench vise
-White lithium based grease
-Shop towels or rags
1. Locate the center plastic panel under the handbrake. Pull up on it to free the clips holding it in place and put it in a safe area for re-installation later.
2. Pull up on the rear plastic panel behind the one you just removed. Put it in a safe place for re-installation later.
3. Remove the stock shift knob by rotating the black ring at the top of the boot about ¼ to ½ turn while pulling down. Lift up on the shift knob to remove from the shaft. This requires some effort as it is a friction fit and there are small white tabs at the bottom of the shift knob that rest in a groove. A small screwdriver may be used to assist in releasing the shift knob while puling it up. Pull up to free the tabs and remove the shift knob.
3. Continued…
The image below shows the shift knob removed from the shifter shaft.
*Note: Pictures are in a Chevrolet HHR
4. Remove the shift boot by placing your fingers under the lip and pulling up to free it. Remove it from the car and put it in a safe place for re-installation later.
5. Gently pull up on the plastic console surrounding the shifter to free the clips holding it from beneath, do not remove it from the car yet. During this step, you will have to disconnect 2 electrical connectors on the under side of the console as pictured below.
5. Disconnect the electrical connectors below the console as shown in the images below.
5. Continued…
With the electrical connectors free you can now remove this part of the console from the car and put it in a safe place for re-installation later.
6. Locate the side panels on each side of the center console and pull on them from the bottom of the panel. They are held on with clips from behind, and the bottom needs to be unclipped first. Remove the panels on each side to uncover 4 screws. Remove the screws using a 7 mm socket and a ratchet.
6. Continued…
7. Remove the 2 screws located behind the shifter.
8. Move the front seats toward the front of the car in order to access the 2 screws (one on each side) at the rear of the center console and remove the screws.
9. The center console can now be removed. To do this, lift the rear of the console while pushing down on the front, and then pull the center console toward the rear of the car and remove it from the car as shown in the pictures below.
9. Continued…
10. With all parts of the console removed you should now have full access to the shift assembly.
Some models may have one or more wiring harnesses clipped to the shift assembly. If your car does not have any wiring clipped to the assembly proceed to the next step.
Remove any plastic clips holding any wiring harnesses to the shift assembly.
11. Put the shifter in 4th gear at this point. Disconnect the white and grey shifter cables attached to the bottom of the stock shifter and to the white plastic side arm. To do so, use a small flat head screwdriver to pry on the front of the grey cap to pop it open. Repeat for the white cap on the driver’s side of the assembly. The caps will not open all the way, they should just click open slightly relieving tension on the cable allowing it to slide freely on the yellow threaded portion of the cable as pictured below.
11. Continued…
Pictured below is the grey cap popped open to allow the yellow threaded shifter cable to slide freely inside it.
12. Disconnect the shifter cables from their anchor points on the shift assembly (shown below with arrows) by lifting straight up on the white plastic frame holding the cable to the assembly. Needle nose pliers may be used to squeeze the tabs on the white plastic frame to allow them to slide out of the anchor points more easily.
Remove the 4 bolts holding the shift assembly to the floor pan using a 13 mm socket and a ratchet with an extension.
13. With the shifter cables free from the shift assembly, it can now be removed from the car. The yellow threaded shifter cables should slide out of the white and grey plastic cable housings to allow the assembly to be removed from the car. Take the shift assembly to a solid work bench or table for disassembly.
14. With the shift assembly out of the car, turn it on its side to have access to the plastic shifter cable housing still attached to the bottom of the shifter. The cable housing can be easily removed by prying it downward as shown below.
15. Put the shift assembly right side up flat on the work table. Use a flat head screw driver to remove the steel “U” shaped clip at the back of the assembly, it will slide out by prying as shown.
16. Rotate the black plastic cap on the shift assembly counter clockwise until it stops. This will allow it to be removed in the next step as the slots for the tabs on the cap are wider when it is rotated counter clockwise.
17. This step is more easily accomplished with the help of an assistant. Use a small flat head screwdriver as shown below to depress one of the 2 small tabs on the cap. There are 3 tabs, one of which is larger than the other 2. Begin by depressing one of the small tabs first. When the tab is depressed, it can be pried upward so the bottom barbed section slides up through the slot in the shift assembly. When the barbed section is almost through the slot, the screwdriver can be used to raise it more as pictured on the next page.
17. Continued…
Repeat for the other small tab. Once the 2 small tabs are free, the larger one will be easy to free from the shift assembly.
18. Remove the black plastic cap from the assembly.
19. Use a punch or a screwdriver and a hammer as shown to punch the plastic pivot pin out of the shift assembly while an assistant holds the assembly in place. Use caution not to damage the plastic pivot pin.
20. Remove the plastic pivot pin from the assembly to free up the plastic side arm at its pivot point.
21. Lift the shifter straight up and out of the shift assembly. The plastic side arm will need to be raised slightly as well to free the shifter from the assembly.
22. Pop the small plastic cup off of the shifter side arm as shown.
Discussion Starter #2
23. Remove the o-ring from the top of the grey plastic pivot cup surrounding the shifter main pivot ball.
24. Remove the grey plastic pivot cup surrounding the shifter main pivot ball as shown. Use caution as this step requires moderate force.
25. Pictured below: The components which have been removed from the stock shifter which are required for installation of the TWM short shifter. Pictured is the shift assembly, rubber o-ring, large grey plastic pivot cup, grey cap cable housing, plastic pivot pin, plastic shift assembly cap, and the small white side arm pivot cup.
26. Turn the shift assembly upside down. Use a small flat head screwdriver to push the steel bushing sleeves out through the top of the assembly and remove the rubber bushings from below as shown below. Having these bushings removed will help in the next step as the shift assembly must be secured in a bench vise. The bushings that are removed in this step will not be re-used for the install as they are replaced with aluminum bushings supplied by TWM. They can be set aside for now but should not be discarded.
27. In order to clear room for the TWM short shifter, the stock plastic shifter assembly needs to be modified as per the illustrations in this step. Secure the shift assembly in a bench vise to modify it. Always wear eye protection and use extreme caution when working with power tools.
The cut-out can be made with a small saw or a Dremel-type tool. TWM strongly recommends a Dremel tool with the type of cutting tool shown below.
27. Continued…
A saw can be substituted if a Dremel tool is not available. Also, be sure to remove the raised tab in the middle (shown in the circle in the picture below).
The small tab on the top side of the shift assembly which must be trimmed is shown below.
Below is the shift assembly seen from below with the cutout completed.
Clean the plastic shavings off of the assembly with a shop towel or blow the assembly clean with compressed air.
28. Apply white lithium based grease to the main pivot ball, side arm pivot ball, and bottom pivot ball of the TWM short shifter.
29. Re-assemble the shift assembly by reversing steps 14 to 24.
The correct order for re-assembly is:
-install large grey pivot cup on to shifter
-install o-ring around top of grey pivot cup
-install small white pivot cup on side arm
-place shifter in assembly
-install pivot pin through white side arm
-install black plastic cap, rotate clockwise
-install steel “U” shaped clip
-turn assembly upside down and pop the cable housing on to the bottom pivot ball of the short shifter.
30. With the shift assembly re-assembled, bring it back to the car for installation. Install the aluminum base bushings included with the short shifter on to the studs beneath the shift assembly with the smaller diameter step facing up. Install a bushing on each stud beneath each corner of the shift assembly and lower the shift assembly on to them, moving the shifter cables out of the way. The yellow threaded portion of the shifter cables should be slid in to the cable housings attached to the shifter. Ensure that the assembly is seated properly with each smaller diameter step on the bushing inserted in the holes at each corner.
31. With the shift assembly properly seated on the aluminum bushings, place one of the stainless steel base bushing washers on to each stud protruding through the assembly, on top of the shift assembly.
32. Secure the shift assembly back in place with the stock nuts and a 13mm socket and ratchet. Be sure the step on the bushings at each corner of the assembly are in the holes in the assembly properly before tightening it down.
33. Re-connect the shift cables that were removed in step 12 to the shift assembly anchor points. Re-secure the shift cables that were disconnected in step 11 to the bottom of the short shifter and the white plastic side arm by closing the white and grey plastic caps on the cable housing. The cables may need to be adjusted to achieve the correct range of motion and desired shifter orientation.
34. Remove the plastic ring at the top of the stock shift boot. To do so, turn the sift boot inside out and cut the nylon zip tie holding the plastic boot holder to the shift boot.
Secure the aluminum boot holder supplied with the TWM short shifter to the shift boot with the supplied zip ties. Secure the boot to the groove in the aluminum boot retainer.
Re-install the center console and shift boot by reversing steps 1 to 10.
You are done, enjoy the drive!
THAT'S IT!! Now all you have to do is ENJOY it every time you SHIFT!
If you have any other questions or concerns you can post in this thread or send us a PM and we will be more than happy to help you out with your Short Shifter install!
Jordan
Team TWM Performance
If I were to perform this surgery are you able to swap back to the stock shifter if I say were to sell the car and want it sold stock?
---------- Post added at 01:57 PM ---------- Previous post was at 01:57 PM ----------
But great DYI!!!!
thanks, just curious since you have to cut that tab out. I plan on this mod at the end of the summer, unfortunately needs to be the last mod I do.
Great DIY! Very detailed!
I printed this out and the shifter came with the same how to printed, FAIL!! Great product, thanks!!!!
****Free Shipping Promotion at TWM Performance****
Hi Everyone,
For june, we’ve decided to offer a first for TWM Performance! Until July 1st 11:59pm ONLY, we’re offering you FREE SHIPPING all TWM Performance products at the links below:
-Short Shifters | TWM Performance Short Shifter Store
-Shift Knobs - TWM Performance Shift Knob Store
Now’s the BEST Time to pick up a Short Shifter, Shift Knob, Throttle Control Unit for your car! We’ve got THOUSANDS of applications and the BEST products on the market for YOUR CAR!
All You need to do is send us an email HERE before July 1st, 2012 at 11:59pm to receive your Free Shipping coupon code
Feel free to ask any questions you may have by posting in this thread, sending us a pm, sending us an email ([email protected]), or by giving us a call toll free at 1-877-655-0540.
Thanks!
Michael Hill
1 - 9 of 9 Posts
