1 - 20 of 63 Posts
Getrag F23
Specifications
Type: transverse front wheel drive, five-speed manual transaxle.
Engine Range: 2.2L-2.4L
Max Gearbox Torque:
170 lb.-ft.
Weight:
102 lbs.
Applications: Chevrolet Cobalt, HHR; Pontiac G5
The Getrag F23 is a three-axis conventional transverse five-speed manual transaxle with fully synchronized reverse gear. It features compact packaging, broad low-torque applications, and reliable operation.
The F23 has two gearsets on each of three parallel shafts – the input shaft, the output shaft, and the intermediate shaft. This three-shaft (also called three-axis) design results in a very short axial length for better packaging. There are three separate shift fork shafts, which hold three shift forks to activate the synchronizer rings for the two gearsets on each of the three gear shafts. The shift forks are activated by a cable system. The clutch release bearing is operated by a concentric slave cylinder that surrounds the input shaft in the clutch housing. A concentric slave cylinder allows more linear clutch feel than an external lever-actuated clutch and release bearing. The input shaft carries the 3rd and 4th gear synchronizer, the intermediate shaft carries the 1st and 2nd gear synchronizer, and the output shaft carries the 5th and reverse gear synchronizer. The aluminum case contains a conventional final drive gearset.
There are sintered bronze double-cone blocker rings on the synchronizers for 1st and 2nd gears, while 3rd and 4th gears use carbon fiber blocker rings, and 5th and Reverse gears use molybdenum on their synchronizers. Carbon and molybdenum are extremely durable friction surfaces that remain stable even under extreme heat. Reverse gear is synchronized, which is a design advantage. That means the vehicle does not have to be completely stationary in order for reverse gear to be selected by the driver. On-going improvements include refinements such as a new synchronizer sleeve for first and second gear that improves cold-weather engagement of the gears.
Several refinements differentiate the applications of the F23: The concentric slave cylinder, which hydraulically actuates the clutch pressure plate, was redesigned to match the engine configuration in the Chevy Cobalt. VUE and ION use a reservoir where brake and clutch fluid share the same reservoir body, although partitions inside the reservoir keep the fluid for each function separate.
Source:GMinsidenews.com
Thanks for the information nugz!:) That's more information then I have available to me at the dealership that I work for!
I've been very happy thus far with my 5-speed and I really like the fact that reverse is synchronized.
It doesn't look like that there are very many on this site that have a 5-speed in a non SS/SC cobalt? I guess that was one of the reasons why I ordered mine, I wasn't able to find very many manuals in an LT(especially an LT3) at the time.:?
There are a good few actually. Including (but not limited to) myself... But I think most of us ended up with LS's for a similar reason. I just didn't want to wait, I needed it that day pretty much...
you need to CITE your source
AAAAHHH, English 1301 flash back...
I can't complain about this 5-Speed, it's the 3rd one that I've owned. Other two was a 89' Honda Prelude Si and a 94' Mustang LX. This 5-Speed is way smoother and shifts shorter then those others. Yes, I know that there are plenty better, but for the money, I'm very happy.:D
Just to let you know there are others out here, I have an 08 Sport with the MM5 tranny and I love it! I found it on the back lot at the dealer near me, hadn't been prepped for the lot yet so I don't think it would have been there long if it got out front
Ok NUGZ...so it says the max gearbox tourqe for these tranny's are 170 ..what happens when you start to get past that ? .... Time for an upgrade ?
mine is an 08 LS with a 5 speed i didnt even have to look for it it was brought to me
Mines a LS 5 speed Manual too Found it in Georgia, I live in VA. I love it
I have an 05 base coupe with a 5 speed. was the only used one(wanted something newer but didnt have the $$$ for an 09) with a 5 speed. didnt want to leave the dealership in an auto...idc how much hp you have,(imo) it isnt any fun without a manny! got it with a lil over 64k, but have been VERY happy with it so far. love how short the shifts feel and with ease.
my transmission problem
I bought my 2006 LT 5 speed brand new. At 15000 i had to take back to dealer cause 2nd would not go into gear, ( i think the sync was bad).
Now at 35000 it is doing it again.
Im getting a used trans at a junk yard and doing all the work meself. Not very fun.
I put pics of how i pulled transmission on my wifes myspace if anybody wants to check out.
MySpace.com - jen and kelvin - 28 - Female - NAVARRE, FLORIDA - www.myspace.com/boisestategirl
Same here.. almost exact same milege also.. But got rebuilt the first time and replaced the second time. Both under warranty
my first was under warranty but since i had wrecked the car they didnt want to do it. My social skills at the dealership were really bad that day.
1 - 20 of 63 Posts
