I just cleaned the headliner for prep work to be airbrushed and use a mild solution of dawn dish soap....blot don't wipe....an a toothbrush mildly used on spots careful not to work. Up the fibers on the headliner....hope it helps ya out....
---------- Post added at 04:25 PM ---------- Previous post was at 04:24 PM ----------
And blot over with clean water to get the soap out....and blot dry and air dry...
For seats, rent a rug doctor and steam clean. Worse comes to worse, you can always reupholster if it bothers you that much. The seat covers were not very expensive.
I always use Purple Power just dilute it to a 1:1 mixture and use a brush and some elbow grease. Then wipe off with a clean rag.
As recommended, most vehicle stains will come out with mild dish soap + warm water. Key is to not over-do the liquids (i.e. more isn't better) and don't scrub hard. Soft brush, circular motion and time are your friends.
