1 - 20 of 28 Posts
I bought by Cobalt back in June and when I got it the headlights were starting get hazy. Not anything too bad but noticeable. I don't think it lowers how much light I'm putting out but it kinda makes the car just look trashy. Is there a cheap and easy way to get them back to being crystal clear? I see those commercials on TV but they seem like gimmicks.
McGuire's sells some stuff for that, its not a gimmick (there's anyways) its a headlight restoration kit and it removes yellowing and hazing, I've used it and it works.
now if the haze you see is really condensation from a worn headlight seal then thats a whole new can of worms lol.
How will I know if it's condensation? It's not really yellowing and the haze isn't evenly spread, it's more along the top. This picture isn't very good as it's a crop of one I already had that was of the whole car. They don't look to bad but they could be clearer.
ya I cant tell by the pic really... but condensation will sorta look like a beer bottle sweating... but on the inside of the lens, like it'll look wet, like a shower door or something y'know?
haze just sorta makes it look flat and shitty and make your headlights look like old aged ones from an old car.
No it doesn't look wet. It's just kind of a light haze. Almost looks like a bunch of tiny scratches. Yeah I'll see if I can get a better picture tomorrow since it's dark now. Looks like I can get a headlight restoration kit online? Anyone have experience with a particular brand? I'd prefer one with a drill attachment.
Edit: I have no idea what a beer bottle sweating looks like since I'm young and innocent.
LOL^ ah I see, I forgot americans cant drink for a while :nahnah
but anyways
the Mguires kit works well, I've used it, if its haze from UV damage and weather it'll fix it, if its scratches from... I dunno anything a pissed of cat to sand paper (for whatever reason) only some wet sanding and a buffer will fix that.
Like the man says this and a buffing ball or pad.
Discussion Starter #14
Well I tried something online that I found involving sandpaper and I started with it and it just totally scratched up my lenses. Did I really screw it up or can I fix those scratches?
Did you just do a test spot?
Discussion Starter #17
It was wetsand but I stopped immediately because it was scratching really bad. I may just ask for new black headlights for my birthday.
Discussion Starter #18
I bought a Turtle Wax Headlight Restoration Kit. It uses wetsanding technique and has a sealant with it so hopefully I can repair the damage of what I did.
Good luck, most likely you will need to use a high grit sand paper (up in the thousands) on the entire lense then a really good buffing.
Discussion Starter #20
In what part of the process would I do that? I saw a video and it has you use a cleaner then buff it, then use different pads (total of 4 or 5), then use another clarifier and a sealer.
1 - 20 of 28 Posts
