21 - 40 of 68 Posts
Discussion Starter #21 (Edited)
I don't think it would be a wheel bearing because I don't hear any sounds from rotation. Going over slight bumps I hear a mild clanking that can be felt in the pedals. I;m wondering if its the tie rod.
But you said you felt vibration, vibration is usually caused by wheels in motion. Maybe you meant rattling, I'm just going by what you wrote.
Discussion Starter #23
I'm sorry I felt a rattles vibration. I just noticed my wheel wells splash guard was missing a body pin so I will see if that helps. If it doesn't I'm at a loss. Everything is secure. That shady from the cv joint had play but so does the other side so I hope it's just that missing body pin
Make sure there's no broken springs
Discussion Starter #25 (Edited)
no broken springs. the splash guard wasnt the issue either. I think its definitely something from steering. When I jerk the steering wheel you can feel and hear a noise.
---------- Post added at 08:58 PM ---------- Previous post was at 07:51 PM ----------
Im now thinking it is the intermediate shaft. When jerking the steering wheel and holding the metal rod that goes into the floor under the steering wheel I can feel the rattle. Is this a simple fix? If so, is there a How to?
Installing it requires removing two bolts and then putting them back in. Might have to remove drivers tire, I did. Took me 1 hour from start to finish. I know the part was like $150 from the dealer. The rattle is probably the u joint part worn out.
Yup, its all one unit. The joint on the outside of the car is the one that goes
Can't tell by looking at a picture, you kinda have to pry it to see if there is movement in the joint.
U joint....
Mine was seized up so bad I could barely move it
Discussion Starter #37
Where should I stick the pry bar?
---------- Post added at 09:41 PM ---------- Previous post was at 08:45 PM ----------
Well I ruled out the ball joint. No movement.
This is the bottom of my control arm bushing.
This is the top of my control arm bushing.
Bushing looks fine. Best bet is to knock the u joint off the shaft and see if it's loose
21 - 40 of 68 Posts
