1 - 10 of 10 Posts
When my front sway bar links were off the car the clunking was gone, but now there back installed the clunking is back. The strut mounts were just replaced.
Car has 120,000 Kilometers on it.
So what is causing the clunking?
A) Control Arm bushings?
B) Struts?
C) The intermediate steering shaft?
D) Ball joints? ( Doesn't click around corners.)
Wait.. so you drove around with your endlinks off and the clunking stopped?:confused: Then I would assume your endlink/endlink bushings are bad...
Edit: Nvm, I just saw your other post and I'm assuming you put new endlinks on.
oh i didnt read that part about the sway bar. yeah i had that problem it's a control arm bushing, ball joint or bad clunky struts. mine was a control arm bushing.
1 - 10 of 10 Posts
