Just picked up a 08 sport with the 2.4 5spd and I've been noticing a vibration in the clutch pedal. I was wondering if this is normal on these cars or possible issue. I've never had this issue on other manuals even with bad clutches. It's not a violent vibration, just annoying. It seems to follow the engine vibration when revving or shifting around 1500rpm or higher. There's little to no vibration at idle and it only exist in the first inch or two of pedal travel. If the clutch is to the floor or just touching the clutch there's no noticeable vibration. I've seen other posts with similar problems but no solutions or conclusions.
Maybe the throw out bearing is starting to dry up.
That's kind of what I'm afraid of. I've had em go bad before and usually they make a lot of noise, so I'm hoping it's something minor or just a common vibration but I might not get that lucky
