I recently upgrade the front blinkers with LED to compliment the rest blinkers. Since the upgrade, the cruise control is not working. Is this normal if you want to have LED’s?
It’s normal that LEDs can mess with the cruise if placed in the third tail light.
Other than the turn signals “ signal “ comes from the BCM and the cruise control signal comes from the BCM too.
So, did you change out your 3rd break lights with LEDs?
Did you replace your new turn signal LEDs with the original bulbs to see if your cruise works again?
I have all LEDs on my exterior lights. Used Sylvania Zevo type. The bulbs that blink, blinker bulbs, had to solder in resistors. Cruise control works like a champ on my ‘06, I use it daily. Don’t use cheap LED brands though. They can cause issues. Phillips also makes good ones.
