I have a m62 sc kit, and I heard I can eliminate the bypass valve and use a bov to get more boost. Anyone do something similar?
I'm not going to criticize you because I honestly don't think you know. You can't use a BOV on that style supercharger because that supercharger connects directly to the intake manifold on the car, thus has no piping for the BOV to be put onto. Only way to get more boost off of the supercharger is to get a smaller pulley for it (the best way to get it), or put a smaller exhaust on it to restrict the flow of the engine more (you get more boost but you loose a lot of power as well as do a lot of damage on your engine/supercharger)I have a m62 sc kit, and I heard I can eliminate the bypass valve and use a bov to get more boost. Anyone do something similar?
First off my friend, Blow off Valves do not increase power. Their nothing more than a release pressure system found in turbocharged vehicles for when after the flow of air is traveled to the turbo itself. If no BOV or bypass valve is attached to the non charged side of the piping (intercooler), the air will blow back to the turbo itself causing later damage to the inducer fins and ball/ceramic bearings.I have a m62 sc kit, and I heard I can eliminate the bypass valve and use a bov to get more boost. Anyone do something similar?
