I am about to purchase 4 steels rims for Cobalt LT 2006. Knowing the rims is 15 inches with 4 bolts, do I need to know bolt pattern ? What is difference between pattern 4 x 100mm and 4 x 113mm ? Any advice ? Thanks
Andy
The difference is 13mm...you HAVE to get 4x100...it's the only thing that will fit. The only way to get something different is to convert your hub to another pattern which would not be worth it to most people.
If the wheels you are looking at are dual pattern (4x100 and 4x113, then that's fine).
Also, I've never seen 4x113...I've seen 4x114.3 though.
