1 - 20 of 25 Posts
Heres all the colors for our cars and the spray can part #'s so you can order them from any GM dealer.
BLACK (41U)-----------------------12345119
OLYMPIC WHITE (50U)-------------12345205
VICTORY RED (74U)----------------12345539
YELLOW (34U)---------------------12346642
LT TRNISH SILVER (67U)-----------12346694
CASMERE MT (15U)----------------12346726
EMERALD JEWEL MET (38U)---------12346798
LASER BLUE MET (21U)-------------12346786
SUNBURST ORANGE MET (56U)------12346722
ARRIVAL BLUE MET (91U)-----------12346648
MAJESTIC AMETHYST MET (84U)----12346219
ULTRA SILVER MET (95U)-----------12345305
PACE BLUE (20U)-------------------88860746
SPORT RED MET (29U)--------------12346746
These part numbers are for 5oz can of spray paint. These will be the best choice if you are trying find paint that is the same color as your car. As alwys when ordering the paint, double check the color code (--U) with the color code on your car. The paint names may have changed from year to year, and with the different models, but the color code will remain the same.
GM List Price for these is $12.20 a can.
This should be a sticky very useful info. Thanks!
This may help you better
2005
WA215M Emerald Jewel Met
WA815K Arrival Blue Met
WA8554 White
WA8555 Black
WA8624 Olympic White
WA8867 Ultra Silver Met
WA913L Sunburst Orange Met
WA9260 Victory Red
WA928L Stealth Gray Met
WA929L Cashmere Met
WA9414 Rally Yellow
WA994L Lt Tarnished Silver Met
2006
WA111B Majestic Amethyst Met
WA218M Laser Blue Met
WA8555 Black
WA9260 Victory Red
WA929L Cashmere Met
WA9414 Rally Yellow
2007
WA408P Pace Blue
WA8555 Black Exterior
WA9260 Victory Red Exterior
WA929L Cashmere Met
WA9414 Rally Yellow
WA964L Sport Red Tint coat
2008
WA403P Imperial Blue Met
WA503Q Ink Slate Met
WA520Q Mystique Blue Flash Mt
WA8555 Black
WA9260 Victory Red
WA929L Cashmere Met Exterior
WA9414 Rally Yellow Exterior
WA964L Sport Red Tint coat Exterior
2009
WA316N Gold Mist Met
WA501Q Carbon Flash Met
WA633R Urbane Moss Met
WA636R Switchblade Silver Mt
WA8555 Black
WA9260 Victory Red
WA9414 Rally Yellow
2010 (Not convinced these are accurate yet)
WA505Q Crystal Claret Met
WA707S Dark Labyrinth Gray Mt
WA721S Pulse Yellow Met Exterior
WA8624 Olympic White Exterior
I thought my color was blue flash metallic. Now I see they have mystique flash metallic? I guess that is the color idk.
those are the same exact thing. just a different name between pontiac and chevy.
Does anyone have the Pontiac Paint Codes? My Window Sticker says Comp Yellow for the exterior color which I believe is the same yellow on the Vette's...
Look in your trunk under the tire cover. There is a plate with every option on your car including colors.
hey guys just wanted to add to this...
although the paint code says like WA8555 the real code is just 8555 the WA isnt part of the code (or at least not important)
also the two digit codes like 41U are more like "dealer codes" if you gave that to a paintshop they probably couldnt pull it up...
each paint color as you all can see has two codes one is the WA number and the two digit/letter combo... both are "right" and both could eventually get you your color depending on where you went...but i know for sure that in the dupont software we use at my shop if you typed in the whole WA number nothing would come up... you have to just use the code after the WA...
dont know if this made sense or helped but there ya go
Good point Killcobalt...we use the Dupont system as well and the WA does not work when mixing colours, same as with pontiac. I had to paint a grand am before and I tried and tried to find the right paint formula for it but the system wouldn't recognize it till I took the WA off
I was told that the color for my car was "Granite Blue" but the chart shows "Arrival Blue". Did GM change the names of some of the color's?
So, My paint code is listed as 928L (stealth gray metallic) but my car is Blue. I would have guessed it should be called Arrival Blue by looking at the color charts earlier in the thread. I bought the car when it was a year old and it appears to be the original paint job (sills, trunk, engine bay are all blue). Did they name the paint that badly or is there something else I'm missing here?
Looking to get an LT w/fogs or an SS 2.4 fascia and I'll need to make sure I get the correct paint. Also, if anyone knows of a used one in this color and either style, I may be interested.
thanks
1 - 20 of 25 Posts
